-   -   Auto box won't start in P or N (https://www.audiforums.com/forum/general-tech-50/auto-box-wont-start-p-n-39294/)
zenman63 Aug 19, 2006 09:22 AM
Hi, I have a Mercedes V280 mpv, but this is a VAG sight! yes, well this engine and auto box is VAG, it's a VR6 2.8 with a VAG 4 speed auto fuzzy logic box.
This is the problem.
Mercedes do not have a clue! it is a hybrid to them.
The van will not start in P or N and thinks it is in R as the parking sensors are on and reverse lights on?
Any help as to where to find the switch or ?
Thanks Ian.
techbod Aug 19, 2006 09:25 AM
RE: Auto box won't start in P or N
inhibitor switch which is designed to prevent it pulling away while in any gear when you start the engine its a safety feature with all automatics, age of car might help
zenman63 Aug 19, 2006 09:27 AM
Thanks its a 2000.
zenman63 Aug 19, 2006 09:29 AM
Would this be box end or stick end? it is very low down and you cannot see anything?
Ian
techbod Aug 19, 2006 09:30 AM
hmm I have very little data on it like where the fuses are, car made from 1997-03 the problem could be a fuse or the switch on the shift lever
techbod Aug 19, 2006 09:33 AM
I doubt its box end unless a wire has come off
zenman63 Aug 19, 2006 10:21 AM
Just spoke to VAG in coventry UK and they found the switch.
It's box end, it folows the cable arm.
Thanks for the help, time to get the spanners out!
Ian.
techbod Aug 19, 2006 11:06 AM
good luck mate;)
zenman63 Aug 19, 2006 03:52 PM
Well picked it up from MB and got it home. had a look underneth and the socket was louse
removed it and cleand it and yes happy days!
MB could not find it and they put a new box in 12months ago!
Ian
techbod Aug 19, 2006 04:18 PM
common problem mate;)
