2001 A6 Service
I just got new Audi plugs and wires installed by my local non-audi mechanic. the Service warning just came on. Does this just come on at a predetermined mileage or is the car actually sensing the need for servicing? I can change oil on the car myself, but what oil is the preferred type? Can anyone tell me how to reset the Service message?
RE: 2001 A6 Service
It comes on at a set mileage and has to be turned off. There are some directions floating around here on how to turn it off but not a single one of them worked with mine.
RE: 2001 A6 Service
Mobil 1 or Castrol Synthec are good. Mann/Mahler for filter. There is a bunch of info if you search in the forum too. Good luck!
You can try this...
Found this on AudiWorld-
Resetting SRI without using VAG 1551 or 1552 Scan Tool (ST) - Switch ignition off. - Press and hold down reset button for trip odometer in instrument cluster. - Switch ignition on while button is pressed down. "Service OIL" appears in the display of the trip odometer. - Release button. - Pull setting knob for time in instrument cluster until "Service OIL" indication is reset. "- - -" appears in display. - Press reset button for trip odometer again, to advance to next service event. - Release button. "Service INSP" appears in display. - Pull setting knob for time -1- until "Service INSP" indication is reset. "- - -" appears in display. - Switch ignition off. |
RE: 2001 A6 Service
If you're interested in a helpful reference that contains the 2001 A6 maintenance scheulde, follow the link in my sig to my registry page. It has a number of links that will provide some good info for a 2001 owner.
| All times are GMT -4. The time now is 02:13 AM. |
