Wheel alignment how to
Example of vehicle data sticker
At the start of MY 98, PR numbers were introduced to facilitate running gear/spring/shock absorber assignment. ‒ - A - indicates PR no. for front axle ‒ - B - indicates PR no. for rear axle The running gear version installed in the vehicle can be seen from the corresponding PR number on the vehicle data sticker. ‒ - Arrow - indicates PR no. for running gear versions In this example, the vehicle is fitted with standard running gear 1BA -arrow-. The vehicle data sticker can be found in the spare wheel well at the rear of the vehicle and in the Service booklet. 1BA = Standard running gear 1BB = Heavy-duty running gear (approx. 20 mm higher) 1BC = Special-purpose vehicles 1BD =Sports running gear (Audi S4) RS4 = Sports running gear (RS4) 1BE = Sports running gear 1BV = Sports running gear (quattro GmbH) 1BQ = Sports running gear (South Africa) 1BT = Heavy-duty running gear (approx. 7 mm higher) 1BP = Heavy-duty running gear (trim position as for 1BA, however with limited bump travel) Vehicles with special running gear -1BC- have the same wheel alignment specifications as the standard running gear -1BA-. ● Sensors properly attached and adjusted; heed manufacturer's operating instructions ● Tread depth on one axle must not differ by more than 2 mm ● Specified tyre inflation pressure ● When performing wheel alignment, make sure neither sliding base nor turntable is on end stop ● Vehicle kerb weight 1) 1) Kerb weight refers to weight of vehicle ready for operation (fuel tank and windscreen/headlight washer system fluid reservoir full, spare wheel, vehicle tool kit, jack) without driver. Spare wheel, vehicle tool kit and jack must be in their specified positions. ● Vehicle properly aligned, bounced several times and allowed to settle ● Check suspension, steering and steering linkage for impermissible play and damage and service if necessary ● Perform wheel runout compensation The permissible wheel runout may already cause the toe-in tolerance to be exceeded. The toe-in can then not be set correctly without performing wheel runout compensation. Wheel alignment must be performed: In the event of running problems Following accident damage If axle components have been removed If one-sided tyre wear is found ill add data its a long process [IMG]local://upfiles/12092/19DAB61CEB9E4A8C8FACDD8EF1299E1D.jpg[/IMG] |
RE: Wheel alignment how to
Wheel alignment
Wheel alignment specifications (front-wheel drive vehicles) Applicable to all engines Front axle Standard running gear (1BA, 1BC) Heavy-duty running gear (1BP) Sports running gear (1BE) Heavy-duty running gear (1BB, 1BT) Camber - 25' ±25' - 40' ±25' - 15' ±25' (1BB) - 30' ±25' (1BT) Max. perm. difference between the two sides 30' 30' 30' Toe per wheel (kerb weight setting) + 10' ±2' + 10' ±2' + 10' ±2' Toe per wheel(kerb weight check value) + 10' ±5' + 10' ±5' + 10' ±5' Toe constant per wheel (setting) + 12' ±2' + 12' ±2' + 12' ±2' Toe constant per wheel (check value) + 12' ±7' + 12' ±7' + 12' ±7' Toe-out on turns at 20 degrees 1) - 1° 20'*±30' - 1° 20'*±30' - 1° 20'*±30' 1) Toe-out on turns at kerb weight 1° 20'*±30' with 20° steering angle at inside wheel Rear axle Standard running gear (1BA, 1BC) Heavy-duty running gear (1BP) Sports running gear (1BE) Heavy-duty running gear (1BB, 1BT) Camber - 1°30'*±20' - 1°30'*±20' - 1°30'*±20' Max. perm. difference between the two sides 30' 30' 30' Overall toe + 20' +15'/-10' + 28' +15'/-10' + 14' +15'/-10' Max. perm. mis-alignment with respect to longitudinal axis of vehicle ±15' ±15' ±15' |
Wheel alignment[/align]Wheel alignment specifications (four-wheel drive vehicles)[/align] Applicable to all engines Front axle Standard running gear (1BA, 1BC) Heavy-duty running gear (1BP) Sports running gear (1BE) Heavy-duty running gear (1BB, 1BT) Camber - 25' ±25' - 40' ±25' - 15' ±25' (1BB) - 30' ±25' (1BT) Max. perm. difference between the two sides 30' 30' 30' Toe per wheel (kerb weight setting) + 10' ±2' + 10' ±2' + 10' ±2' Toe per wheel(kerb weight check value) + 10' ±5' + 10' ±5' + 10' ±5' Toe constant per wheel (setting) + 12' ±2' + 12' ±2' + 12' ±2' Toe constant per wheel (check value) + 12' ±7' + 12' ±7' + 12' ±7' Toe-out on turns at 20 degrees 1) - 1° 20'*±30' - 1° 20'*±30' - 1° 20'*±30' 1)Toe-out on turns at kerb weight 1° 20'*±30' with 20° steering angle at inside wheel Rear axle Standard running gear (1BA, 1BC) Heavy-duty running gear (1BP) Sports running gear (1BE) Heavy-duty running gear (1BB, 1BT) Camber -40'*±30' - 40'*±30' -40'*±30' Max. perm. difference between the two sides 30' 30' 30' Overall toe 16' ±10' 16' ±10' 16' ±10' Max. perm. mis-alignment with respect to longitudinal axis of vehicle ±10' ±10' ±10' 1)Vehicles with heavy-duty running gear = 1BT only |
Wheel alignment[/align]Wheel alignment specifications (front-wheel drive vehicles with aluminium mounting bracket)[/align] Applicable to all engines Front axle Standard running gear (1BA, 1BC) Heavy-duty running gear (1BP) Sports running gear (1BE) Heavy-duty running gear (1BB, 1BT) Camber - 35' ±25' - 50' ±25' - 20' ±25' (1BB) - 30' ±25' (1BT) Max. perm. difference between the two sides 30' 30' 30' Toe per wheel (kerb weight setting) + 10' ±2' + 10' ±2' + 10' ±2' Toe per wheel(kerb weight check value) + 10' ±5' + 10' ±5' + 10' ±5' Toe constant per wheel (setting) + 9' ±2' + 9' ±2' + 9' ±2' Toe constant per wheel (check value) + 9' ±7' + 9' ±7' + 9' ±7' Toe-out on turns at 20 degrees 1) - 1° 20'*±30' - 1° 20'*±30' - 1° 20'*±30' 1)Toe-out on turns at kerb weight 1° 20'*±30' with 20° steering angle at inside wheel |
Wheel alignment[/align]Wheel alignment specifications (four-wheel drive vehicles with aluminium mounting bracket)[/align]
Wheel alignment[/align]Wheel alignment specifications (sports running gear 1BD, RS4)[/align]
Front axle Sports running gear 1BD Sports running gear RS4 Camber - 50' ±25' - 1° 10'*±25' Max. perm. difference between the two sides 30' 30' Toe per wheel (kerb weight setting) + 10' ±2' + 10' ±2' Toe per wheel(kerb weight check value) + 10' ±5' + 10' ±5' Toe constant per wheel (setting) + 7' ±2' + 7' ±2' Toe constant per wheel (check value) + 7' ±7' + 7' ±7' Toe-out on turns at 20 degrees 1) 1° 20'*±30' 1° 20'*±30' 1)Toe-out on turns at kerb weight 1° 20'*±30' with 20° steering angle at inside wheel Rear axle Sports running gear 1BD Sports running gear RS4 Camber - 55'*±15' - 1° 10'*±15' Max. perm. difference between the two sides 30' 30' Overall toe 16' ±10' 16' ±10' Max. perm. mis-alignment with respect to longitudinal axis of vehicle ±10' ±10' |
Wheel alignment[/align]Wheel alignment specifications (sports running gear 1BV, 1BQ)[/align] Front axle Sports running gear 1BV quattro GmbH Sports running gear 1BQ South Africa Camber - 1°*±25' - 45'*±25' Max. perm. difference between the two sides 30' 30' Toe per wheel (kerb weight setting) + 10' ±2' + 10' ±2' Toe per wheel(kerb weight check value) + 10' ±5' + 10' ±5' Toe constant per wheel (setting) + 9' ±2' + 9' ±2' Toe constant per wheel (check value) + 9' ±7' + 9' ±7' Toe-out on turns at 20 degrees 1) 1° 20'*±30' 1° 20'*±30' 1)Toe-out on turns at kerb weight 1° 20'*±30' with 20° steering angle at inside wheel Rear axle Sports running gear 1BV quattro GmbH Sports running gear 1BQ South Africa Camber/front-wheel drive - 1° 50'*±20' 2) - 1° 30'*±20' 2) Camber/four-wheel drive - 55'*±15' 3) - 40'*± 30' 3) Max. perm. difference between the two sides 30' 30' Overall toe 35' +15'/-10' 2) 16' ±10' 3) 25' +15'/-10' 2) 16' ±10' 3) Max. perm. mis-alignment with respect to longitudinal axis of vehicle ±15' 2) ±10' 3) ±15'2) ±10'3) Additional data for vehicles with front and four-wheel drive: Additional data are only intended to speed up diagnosis after an accident. |
Wheel alignment[/align]Preparation for measurement[/align]Special tools and workshop equipment required ◆V.A.G 1813 Wheel alignment computer ◆V.A.G 1869/2 Brake pedal depressor ◆V.A.G 1907 Screw for steering centring ◆V.A.G 1925 Spacer gauge ◆V.A.G 1925/3 Adapter ◆V.A.G 1925/4 Adapter [/ul] Use of adapter V.A.G 1925/3 or V.A.G 1925/4 depends on design of lifting platform. ◆V.A.G 1925/6 Adapter set [/ul] Wheel runout compensation Compensation must be provided for lateral runout of rims. Otherwise measurement result will be biased. The toe-in cannot be set correctly without performing wheel runout compensation. ‒Perform wheel runout compensation. [/ul] Heed appropriate instructions of wheel alignment equipment manufacturer when doing so. [/ul] ‒→ Insert brake pedal depressor V.A.G 1869/2. [/ul] Crash vehicles Screw for steering centring V.A.G 1907 must be inserted when performing wheel alignment on such vehicles. Otherwise centre position of rack is not guaranteed. Screw for steering centring V.A.G 1907 is only to be hand-tightened |
#1 that's enough for today;)
[IMG]local://upfiles/12092/179B68C78D5F4059B0A0FFE942B34706.jpg[/IMG] please don't reply to this post its a how to only;) |
Wheel alignment[/align]Assignment of adapters to running gear for alignment[/align]
Adapter Standard running gear (1BA) Heavy-duty running gear (1BB) Special-purpose vehicles (1BC) Sports running gear Audi S4 (1BD) Sports running gear (1BE) V.A.G 1925 X X X X X V.A.G 1925/4 X X X X X V.A.G 1925/6 X X X V.A.G 1925/3 1) X X X X X 1)Only required on certain lifting platforms. V.A.G 1925/3 replaces V.A.G 1925/4. Adapter Heavy-duty running gear (1BP) Heavy-duty running gear (1BT) Sports running gear (1BV) quattro GmbH RS4 Sports running gear (1BQ) South Africa V.A.G 1925 X X X X X V.A.G 1925/4 X X X X X V.A.G 1925/6 X X X X X V.A.G 1925/3 1) X X X X X 1)Only required on certain lifting platforms. V.A.G 1925/3 replaces V.A.G 1925/4. |
| All times are GMT -4. The time now is 07:28 PM. |
