-   -   Odometer LED not display in both top and bottom mileage counter (https://www.audiforums.com/forum/electronics-30/odometer-led-not-display-both-top-bottom-mileage-counter-53546/)
paulshiu Feb 4, 2007 11:12 AM
Model : Audi A4 2.6 V6 year 1995
Problem : both top and bottom mileage counter not display - odometer LED display totally black (location of odometer : inside the speedometer in the front panel)
Looking for root cause and solution.
Send email to
paul_shiu@hotmail.com
[IMG]local://upfiles/30360/D2175773751B417FA86C6CAB0F055E39.jpg[/IMG]
[IMG]local://upfiles/30360/DE93A1F9BEB4491CBF40D747D2865EAE.jpg[/IMG]
SloRide Sep 7, 2007 10:12 AM
RE: Odometer LED not display in both top and bottom mileage counter
How did you make out with this problem? I'm having the same issue. I also had the outside temp and shift indicator bulbs burn out awhile ago and fixed it with this procedure....
http://www.12v.org/maintenance/repairs/backlight.php thanks
but I'm not sure the odo light is accessible beacuse odo's are typically a sealed unit to prevent millage roll back.
Rgriff Nov 6, 2007 04:25 PM
HI
it is just a bulb with a baynet style connection like the others on the rest of the cluster .
please be aware if you buy off ebay most are L.E.D s and need the bulb brightness turned up (same controle that sets the clock) also they have to be connected to positive and negative . so if theye don't work turn ignition off completely and rotate 180 deg .
if the led comes out of baynet housing please be carefull how you replace as you can cause a short if your out by 90 deg like i did now there is no power to bulb [:@].
hope this helps.
