-   -   TDC Mark (https://www.audiforums.com/forum/audi-a6-9/tdc-mark-57166/)
wings7351 Mar 13, 2007 02:33 AM
TDC Mark
I'm about to change my timing belt, trying to put the engine at TDC. Everybody is talking about a TDC mark on the crankshaft pulley, but I just can't find any obvious mark on the shaft or on the pulley. Can anyone help? Mine is a 99 A6 2.8 30V
Thanks..
auditech79 Mar 13, 2007 04:39 AM
RE: TDC Mark
Look harder man its there, use a good flash light and rotate the engine over by hand until you see that notch on the crank pulley, when you do use some white out on it so you don't lose it again.
wings7351 Mar 13, 2007 03:13 PM
RE: TDC Mark
Auditech79, so it is on the pulley, not the shaft, right? would you have a picture of it? Thanks.
techbod Mar 13, 2007 03:33 PM
RE: TDC Mark
[IMG]local://upfiles/12092/F1D1A240771A47B0A72229896289C181.jpg[/IMG]
prbayha Mar 13, 2007 04:39 PM
RE: TDC Mark
Use a timing light and some white out to mark TDC. Should be fairly easy to read with the light.
techbod Mar 13, 2007 04:47 PM
RE: TDC Mark
timing light is only useful when the engine is running and as its a refit of new parts this is not practical ( not that you could do anything even with it because its computer controlled ) the timing that is, fitting a new timing belt is a static thing ( remove and replace );)
prbayha Mar 13, 2007 05:01 PM
RE: TDC Mark
true..I didn't think that the engine wasn't running due to the T-Belt ...duh..DISMISS ADVICE!
