-   RS Model Line (https://www.audiforums.com/forum/rs-model-line-48/)
-   -   2001 RS4 MTM 337kw kit Losing Boost (https://www.audiforums.com/forum/rs-model-line-48/2001-rs4-mtm-337kw-kit-losing-boost-57584/)
RAG Mar 17, 2007 05:30 AM
2001 RS4 with recently fitted MTM 337kw kit loses boost after simultaneous starts (say 3 or 4 times but is somewhat random). Can scan engine and clear fault codes and boost comes back on.
The fault codes are "Lean on both banks". Checked exhaust AFR with independant meter which showed 14.5 on idle and between 14.4 and 15.3 on full boost. Does anyone know what the expected AFR should be on this MTM kit or if anything else could be causing the loss of boost. I'm speed deprived!!!!
CamoA6 Mar 19, 2007 12:07 PM
RE: 2001 RS4 MTM 337kw kit Losing Boost
Try checking for vacum leaks. I had both banks running lean in my 2.7T cleared codes performance came back. does your car have trouble starting in the cold sometimes?
RAG Mar 20, 2007 11:11 AM
Have cleared codes and boost comes bank.... till next time I drive in traffic and stop/start approx 3 times.....then back to limp mode.
No problems starting.
AFR ratio is 14.5 to 15.3 under boost.
Error codes still "Lean on both banks"
Driving me nuts (wish it were boosting me nuts)
CamoA6 Mar 24, 2007 05:32 PM
Sounds like a vacuum leak. check the line to your fuel trim bank. on the left side on the engine bay under your top left engine cover. my line is torn but cars performance is still okay.
Flip Mar 26, 2007 05:39 AM
14.5 at idle sounds good but 14.4 to 15.3 on boost sounds a little high but I may be wrong.
Jeff Mar 28, 2007 06:44 AM
that seems way to lean to be at 14.4 on boost. at idle you want to be at 14.7 boost around 11.5. at least thats what im going for on my car
