-   -   Audi 80 1990 (b3) just bought - answers needed!! (https://www.audiforums.com/forum/all-other-audi-models-11/audi-80-1990-b3-just-bought-answers-needed-57915/)
maudi80 Mar 20, 2007 04:11 AM
Hi there! im obviously new here so i thought id say hi...and hit u guys with some questions :)
just got an 80 b3 and im wondering:
- is it possible to fit the red rear indicator lights from a b4 to a b3? same goes for the front clear ones..
- has any1 replaced the 4" front speakers with 6"? how did u do it??
mm..thats basically it so far, hope someone can help me out!
thanks,
maudi
InExile Mar 22, 2007 10:06 PM
RE: Audi 80 1990 (b3) just bought - answers needed!!
lights sould be no problem ... well for the speakers just think of somthin'
kakarot Mar 23, 2007 11:06 AM
rear yes but need a rear panel.
front no, unless you have a B4 hood with appropriate lights in already.
Speakers, that would mean cutting. Better just install them somewhere else, like front doors.
trippin13 Mar 27, 2007 12:39 AM
hey did you manage to work out if there is a way to close the airway in the car completely? Even when the fan is switched off the air from outside seems to be pumped inside ... so for example when it stinks outside I can't seem to close off the vents apart from manually closing each on the dashboard but even then bit of air comes in through other entry points (legs and windscreen way)... usually there is a switch to flick to internal airflow but no such thingon this car.... ???
Also do you maybe have directional tires on this car?
I do and they make the steering quite annoying ... steering wheel pulls to left or right
at times ...
cheers
