-   -   weirdness from the rearend (https://www.audiforums.com/forum/audi-a4-8/weirdness-rearend-64096/)
dombombBMX May 20, 2007 05:38 AM
hi to all the audi lovers... if you could help try to diagnose this problem that would be so awesome....
first question i have is..... I hear a slight humming from the rear end, maybe a ever so slight kind of grinding noise.. it goes away when i turn right. stays when i turn left. it isnt the brakes, i have applied pressure and the pattern of the sound doesnt differ... it doesnt sound to serious but i just want to know what it might be... just hearing this weird noise you know is not suppose to be there is annoying. i dont know as much as most guys that post here so any help is greaty appreciated...
also... i see small specs/dots of what might be rust forming? if it is how can i stop this from forming bigger... any tips?
thanks in advance
CRAZYHAWK May 20, 2007 08:33 AM
RE: weirdness from the rearend
Right wheel bearing needs replacement.
dombombBMX May 20, 2007 02:36 PM
alright.. yeah that sounds like it might be the problem.. i thought it might be.. ill probably get some new wheel bearings and see what happens...
if anyone has any other suggestions let me know.
anybody know anything about this rust nonesense?
take it easy alll
techbod May 20, 2007 02:41 PM
RE: weirdness from the rear end
jack each wheel of the ground an spin them and listen for bearing noise ( there should be no noise at all ) just simply a smooth rotation
dombombBMX May 22, 2007 03:28 AM
you can just jack one wheel up, and spin 1 wheel on an all wheel drive car.... wont the other wheels spin aswell?
anybody have any suggestions on what that odd noise could be...?
thx peoples
Belligerenceā„¢ May 22, 2007 05:40 AM
ORIGINAL: dombombBMX
thx peoples
no, the diffs on our cars are not limited slip, unfortunately. you can jack up any one wheel and spin it, provided the car isn't in gear. if you tried to spin both rears or both fronts, that's where you'd have a problem.
david9999 May 22, 2007 06:42 AM
Wheel bearing most likely.
Redrum1 May 22, 2007 10:13 AM
Does it make the noise on all types of road surfaces? Mine has a set of GoodYear Eagle RS-A that were on it when I bought it and on certain road surfaces like the brushed concrete they howl like all the bearings were gone. As soon as the road surface changes they run quiet again. Just thought I would throw this in the mix. If the tires are ruled out I would say wheel bearing also.
BaconBait May 22, 2007 10:45 AM
Wheel bearings also have a tendancy to go out in pairs. Myrear rightwent out and a week later the left went.
ironman May 22, 2007 11:58 AM
i replaced one wheel bearing already and i dont raelly want to do another one.
