Heat Wrap Testpipe?
I am about to buy, and install a test pipe on my 98 1.8t, and I was justwant some opinions on heat wrapping the test pipe? Do you think that this will help keep the heat down and make it run cooler? thanks
RE: Heat Wrap Testpipe?
heat wrap has been proven to be a bad thing. it overheats the metal pipe, and will cause it to break down more quickly. here's an article on it:
http://www.centuryperformance.com/heatwraps.asp |
ceramic coating would be a better solution..
a ceramic coated exhaust manifold, TP, and hotside of your turbo would be very beneficial in retaining heat to make more effecient power and keep it out of the engine bay |
sean hit the nail on the head, ceramic coating is where it's at.
you can even do your intake manifold, and any hard intercooler piping you have. it'll help stop heat from soaking into them. |
ORIGINAL: Belligerence™ you can even do your intake manifold, and any hard intercooler piping you have. it'll help stop heat from soaking into them. there is a reason that all intercoolers and intercooler piping is made out of aluminum. it disipates heat more than any other metal out there for the price. so it is ok for it to get hot becase it will eventually cool down.. if it was ceramiccoated then it would eventually heat up, andthen take forever to cool down. thus heatsoak would be more prone.. and on the intake manifold, basicallythe same thing.. best solution you could do to keep engine bay heataway from the IM is to make a heat sheildover/around it.. i would like to see something like that actually |
ORIGINAL: sean1.8t ORIGINAL: Belligerence™ you can even do your intake manifold, and any hard intercooler piping you have. it'll help stop heat from soaking into them. there is a reason that all intercoolers and intercooler piping is made out of aluminum. it disipates heat more than any other metal out there for the price. so it is ok for it to get hot becase it will eventually cool down.. if it was ceramiccoated then it would eventually heat up, andthen take forever to cool down. thus heatsoak would be more prone.. and on the intake manifold, basicallythe same thing.. best solution you could do to keep engine bay heataway from the IM is to make a heat sheildover/around it.. i would like to see something like that actually |
uhhh... not to sure about ceramic coating being bad... lets think about this, the space shuttles are completely covered with ceramic tiles keeping the outer shell just below the tiles cool. Yes aluminum disapates heat better, but if it has a preventative heat-soaking coating, then how could that be bad?
i have a jet coated exahust manifold and it keeps the engine bay temps down
[/align] [blockquote] [/align] [blockquote] ORIGINAL: B5luver uhhh... not to sure about ceramic coating being bad... lets think about this, the space shuttles are completely covered with ceramic tiles keeping the outer shell just below the tiles cool. Yes aluminum disapates heat better, but if it has a preventative heat-soaking coating, then how could that be bad? reason being: heat is built up in the inside, so it has no place to escape if it is coated. thus, it would just get hotter, and hotter, and heatsoak would be excrutiating.. besides, the piping isn't by anything that would heat soak it. andmost of the piping is in the area with the most air velocity. there are just certain things that NEED to disipate heat, and the FMIC along with it's piping is on the top of the list.. otherwise, top FMIC kit manufacturers would all include a ceramic coating option for their piping. and you would see it on every race car EDIT- not to sure why when i post it spaces it way down to the bottom..[/blockquote][/blockquote] |
ORIGINAL: B5luver uhhh... not to sure about ceramic coating being bad... lets think about this, the space shuttles are completely covered with ceramic tiles keeping the outer shell just below the tiles cool. Yes aluminum disapates heat better, but if it has a preventative heat-soaking coating, then how could that be bad? |
| All times are GMT -4. The time now is 02:45 AM. |
