BIG NEWS on my S4.
Well guys, the yellow duck has returned from boot camp (AWE).
I'll have a complete story and a "fitness" report on how well she performs by Monday. As for now, I'm off for the weekend to test out the new duck. |
RE: BIG NEWS on my S4.
sweet o man you are my idle I just wish I had that kinda cash must be nice to be rich like yourself
BTW did u get the kit with the manifolds or without ? |
Everything...
Kit w/manifolds. DP's Clutch kit Timing belt Blah blah blah... |
Someone spent a pretty penny. Imola, which clutch did u get? I went with the stg 3.
Just the RS4 kit.
Don't want to replace it often - I won't be launching at the track either. |
Wow dude, you are going to have SOME car there!
Ahhh imola, we all say that, just wait, ull lighting all 4 up.
OKEY DOKEY............
This is siiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiick!!!!!! Due to crazy weather over the weekend, I didn't take the duck out for a good test. But today, 66 degrees, clear skies, open roads.............. So.............. Ahem............ Well, it's certainly no "duck"! I'm going to have to come up with a new moniker for the yellow beast, 'cause that's what it is - a beast! I'll start off by telling you guys that it was dynoed at 12 noon, ambient temp = 62 degrees. It dynoed at 352.0 hp (at the wheels) and 450.6 (at the crank) - peaking at 6750rpm. The data was corner weight corrected and heat soak corrected to 371.4 hp (at the wheels) and 475.4 hp (at the crank). The torque was 345.2 ft-lbs (at the wheels) and 441.9 ft-lbs (at the crank) - peaking at 4500rpm. The torque numbers were corrected to 364.2 ft-lbs (at the wheels) and 466.2 ft-lbs (at the crank). DAYUUUUUUM!!!!!!!! Real world driving impression: (see comment in red above) EDIT: I'll have some real world driving numbers by tonight. |
those are some impresive #'s man you need to get to the track with that and see if you can hit mid 11's like that blue one did ;)
Not a bad idea.... maybe next weekend.
| All times are GMT -4. The time now is 09:49 PM. |
