20's
can 20" rims on a A6? what is the biggest size?
RE: 20's
20's fit, a couple guys have them here. I just recommend for performance sake that you find the lightest weight ones you can, and I hope you live in an area with great roads! Also double check backspacing. 35mm is recommended.
RE: 20's
ill stick with the 19's that I have then?
RE: 20's
RE: 20's
You can also do a search on this topic as it has been discussed many times. You'll find a lot of info probably since it has been covered recently.
RE: 20's
Covered many times! It ends up to be to each their own. I have 19's and have to watch the roads for potholes. You are seriously gambling with 20's
OOOO |
| All times are GMT -4. The time now is 02:14 PM. |
