Check Engine and 4 psi of boost in my '01 A4 1.8T
Hi guys!
My check engine light is on and luckily, someone helped me download the codes. Here they are. The only code that had any "comments" in it was the first one. The rest didn't say anything else so I just wrote down the trouble code and description. Could anyone help me with my car? It's a 2001 A4 1.8T. I'm going to a driver school soon and would like to get it fixed before then. Thanks!!! Trouble Code : P0444 Description : Evaporative Emission Control System Purge Control Valve Circuit Open Comments : Engine Status Fuel Pressure (Gage) : Intake Manifold Pressure (Absolute) : Engine Coolant Temperature : 113.00 °F Calculated Load Value : 3.5 % Engine Speed : 800 RPM Vehicle Speed : 0 MPH Fuel Trim Status Short-Term Fuel Trim (Bank 1) : 0.00 % Short-Term Fuel Trim (Bank 2) : Long-Term Fuel Trim (Bank 1) : -0.78 % Long-Term Fuel Trim (Bank 2) : Fuel System Status Fuel System 1 Status : Fuel System 2 Status : Open loop; has not yet satisfied conditions to go to closed loop. Trouble Code : P0037 Description : HO2S Heater Control Circuit Low (Bank 1, Sensor 2) Trouble Code : P0418 Description : Secondary Air Injection System Relay "A" Circuit Trouble Code : P0412 Description : Secondary Air Injection System Switching Valve "A" Circuit Trouble Code : P1289 Description : Unknown Powertrain DTC (Manufacturer Controlled; Fuel and Air Trouble Code : P1472 Description : Unknown Powertrain DTC (Manufacturer Controlled; Auxiliary Trouble Code : P0031 Description : HO2S Heater Control Circuit Low (Bank 1, Sensor 1) Trouble Code : P0136 Description : O2 Sensor Circuit Malfunction (Bank 1, Sensor 2) Trouble Code : P0102 Description : Mass or Volume Air Flow Circuit Low Input Trouble Code : P0135 Description : O2 Sensor Heater Circuit (Bank 1, Sensor 1) |
RE: Check Engine and 4 psi of boost in my '01 A4 1.8T
Welcome to Audi Forums audigirl929!
Since you're new... check out the START HERE! (click this link) link to get a rundown of the lingo/vocab here at audiforums. Then be sure to search the archives when you have a question. Chances are the question has been asked before (probably several times) and the archives will have plenty of information to answer your question. If you still need answers, please feel free to ask questions. Don't feel intimidated; we are all a bunch of pretty cool guys (and gals). Feel free to post advice, comments, ideas, suggestions, and even pics. ================================================== ========================================== Good to see a GIRL on the forum. I don't have my reference CD tonight... or I'd be able to answer all these questions. I'll have it up and running tomorrow if nobody responds with anything concrete today. |
Just to add, I have the APR chip and exhaust - but I never had any problems with it for the 3 years I've had it (and no, me modding the car was not boyfriend induced - a lot of my female friends ask me that). Although I'm still getting 4psi of boost (vs. 10ish stock and spike to 17ish APR'ed), the car does run smooth with no hesitations. It just won't go to full boost. Although we "resetted" the check engine light, it will come up again after the 2nd engine start. A mechanic told me that the system won't go to "closed loop" - but I have no clue as to what that means. They found no broken hoses, changed spark plugs, and changed the air filter. The problem is still there... :( And today, the AC doesn't seem to be blowing cold air. My baby is falling apart approaching 100k miles. :(
Thanks in advance for anyone who can help me! |
Wouldnt a bad diverter valve cause the car to yeild low boost levels?
No idea on the CEL's though.... |
i know you said the mechanic checked your vacuum hoses but i think they should be checked again
reason being the number of secondary air injection codes and the mass air flow codes. do you have acess to a repair manual? bentley has good diagrams of the evap system routing. i am guessing a leaking hose or maybe a bad combination valve to secondary air injection pump. that valve is commonly know to go bad. it is located between the back of the valve cover and the firewall |
oh yeah, i am guessing you have a boost gauge.
also check the hoses and fittings where it is tapped in. |
one last thing, check all of the one way check valves in the evap system as well
w/o fixing these problems ur not going to be able to boost past stock boost bc ur car is in limp mode..this is a saftey mod for when ur check engine light comes on so untill u fix this problem ur not gonna see any boost.
thats why i got the 2.8
I can take the boost gauge hose out of the equation by un-Ting it from the hose coming out of the intake manifold. I'll try this out today during lunch.
>>>i am guessing a leaking hose or maybe a bad combination valve to secondary air injection pump. that valve is commonly know to go bad. it is located between the back of the valve cover and the firewall Black B5: Can you post a pic as to where this might be? >>Wouldnt a bad diverter valve cause the car to yeild low boost levels? I assume that if I had a bad DV, that the boost would be "erratic" and the car would run crappy (hesitates, stalls, etc.)??? 'Cause right now, it's pretty contant at 4 psi and the car runs pretty smooth...just slow... |
| All times are GMT -4. The time now is 10:11 PM. |
