'97 A6 Headrest Removal??
Trying to put on sheepskin seatcovers and can not figure out how to remove the headrest?
It is not in the stock manual? May sound silly, the rear come off easily, but the front do not have an obvious means of removal, is there a special tool? Any help is hugely appreciated!! Thanks |
RE: '97 A6 Headrest Removal??
Not sure how to take the front ones off all I would say is pull which might not be the best idea but how did the rear ones come off?
I just went out and tried and i just held the button down till they were all the way up and then I kept pulling and leaned the seat back because i needed more room and it just came off....with the bars still attached but it came off.
do you know how to get the driver and passenger head rest out of an 1997 audi a6 quattro
'97 Audi A6 front headrest removal
Sit in the rear seat. Pop up the matching color circle trim piece.
Look under the left side of the white connector. There is a small round cutout that partially reveals a wire spring clip. Using a small flat screwdriver, hold back the leather while sliding the pin to the left and out. Do the same for the other headrest post. Pull up and slide of the headrest assembly. |
| All times are GMT -4. The time now is 09:14 PM. |
