-   -   audi recall (https://www.audiforums.com/forum/general-tech-50/audi-recall-83704/)
hellperados Dec 4, 2007 08:45 PM
audi recall
hi
I just bought 2 month ago a 1997 a4 2.8 quattro. I'm wondering if all the recall has benn done on this car. How can I check that? Should I go to a dealer?
Also , the cruise control and the interior door lock are not working. Any ideas of what could it be?
Thank
Remi
Deanne Dec 4, 2007 09:09 PM
RE: audi recall
you can call an Audi dealer and give them your VIN #....they can check for recalls and confirm if they have been done on your car.As far as the two other problems...sorry can't help you there.
99A6Q Dec 5, 2007 11:06 AM
RE: audi recall
Another way to check for recalls is carfax. If you run a carfax on a car and there are pending recalls that have not been done yet carfax USUALLY will let you know.
As far as the other things. Could be a number of things, try checking some fuses first.
hellperados Dec 5, 2007 07:01 PM
RE: audi recall
I'll call a dealer tomorrow.
For my cruise control , I check all the fuses and they're all ok but the onwer manuel said that the cruise control fuse is at position 11. If i look at the position 11 in the fuse box it's a spare , there is nothing connected at this place.
AZAudiA6Q Dec 6, 2007 01:22 PM
RE: audi recall
From what I've read around these forums, these problems usually come down to a bad relay or switch somewhere. Try seeing if you can trace the problem back to its origin, otherwise it looks like you'll need some dealer help.
ORIGINAL: hellperados
hi
Thank
Remi
