Brake upgrade DIY
see below
RE: Brake upgrade DIY
go back and edit by pressing the "Add image" button (bottom row, far right) and then add in the photobucket links. Thank you
13 Attachment(s)
ORIGINAL: manufan
A fairly simple, affordable and effective upgrade. A8 312mm rotors with TT caliper carriers, to replace directly, the 288mm rotors and carriers of the A4's front brakes. WHEEL DIAMETER LIMITATION - no smaller than 16" diameter wheels. 1) After safely raising and supporting the front end of the car, remove the front wheels. 2) Beginning with the spring clip on the brake caliper, use a small flat blade screwdriver to lever the clip away from the caliper at the point where it enters the caliper. Attachment 60904 3) Locate the (2) plastic plugs on the back of the caliper, pry them out with the same flat blade screwdriver. Attachment 60905 4) Using a 7mm allen and ratchet, remove the (2) caliper slider bolts. [Installation note] torque these bolts to 18 ft/lbs during re-assembly. Lightly coat the slider surface with silicone grease. Attachment 60906 5) Using a small pry bar or large screwdriver remove the caliper from the rotor. Swing caliper around and rest it on the lower control arm. Do Not allow it to hang from the brake hose. Attachment 60907 6) Locate the (2) bolts holding the caliper carrier to the spindle housing. Using a 17mm socket and long ratchet, remove these bolts. They're VERY tight. If available, an impact gun can be helpful with these. [Installation note] torque these bolts to 92 ft/lbs during re-assembly with a light coating of anti-seize on them Attachment 60908 Attachment 60909 7) Remove the caliper carrier and rotor. The rotor will fall off of the hub once the carrier is removed, use care to keep it from falling on your foot. 8) Using a wire brush and light oil, clean off the rust/scale from the hub. Attachment 60910 9) Using care to not get oil/grease/anti-seize contamination on the braking surface of your new rotors, place the rotor on the hub. While holding it in place, attach the new TT carrier and tighten to the specified torque. (92 ft/lbs) Attachment 60911 10) With a c-clamp or large water pump pliers, carefully squeeze the piston back into the caliper. Keep an eye on the level in the reservoir when you do this and if the level goes over the MAX mark, use a "turkeybaster" to remove some of the fluid and dispose of it appropriately. Attachment 60912 11) Clean off any residue from the slider bolts and apply a very light coating of silicone grease to them, slide them back into the calipers. Attachment 60913 12) Again, using care to not get contamination on your new pads locate the inner pad with the spring into the piston. Place the outer pad in the grooves on the carrier. Slide the caliper over the outer pad and rotor and reattach with the slider bolts to the specified torque (18 ft/lbs). Replace the cover caps. Attachment 60914 13) By first placing the open ends of the spring clip into the holes on the caliper, flex the spring back into position. Attachment 60915 14) This is the view from under the car of the wheel/caliper clearance. Attachment 60916 15) Mount the wheels back on the car. Lower the car. Tighten the wheels completely. Before going on your test drive, press the brake pedal down several times to get the pads to contact the rotor. Avoid hard stops for 100 miles or so to allow the pads to "bed" into the rotors. questions or comments to manufan at audi forum or gkoch60@gmail.com |
sick.. thanks man thats next on my list:)))
My pleasure. If only I was bright enough to embed those photos. Thanks to cincy for the help.
This is sick man thanks, and to think I was gonna do a brake change this week this gives me an even better idea. Thanks Alot man.
Great write-up and pix.
The only task I will add for myself at that point is to paint the calipers. |
how about a few words on how it performs in comparison with the OEM setup?
Thanks for the info. |
Would this upgrade fit al A4's, or just certian years?
i noticed that my pedal wasn't as "grabby" after i did the a8 brake upgrade, much smoother initial braking, but when you really get into it, it yanks the car down from any speed, without a problem.
less dust, less noise, smoother initial braking, firmer/quicker "hard braking" stops. and the car tracks straight under very hard braking, it doesn't follow the road contours at all. in addition to the slotted/x-drilled rotors, i also installed hawk hps pads. i am VERY pleased with the upgrade, well worth the $400 or so it cost me. |
| All times are GMT -4. The time now is 04:13 PM. |
