-   -   A4 Key Reprogramming (https://www.audiforums.com/forum/audi-a4-8/a4-key-reprogramming-89573/)
jason955 Jan 29, 2008 11:26 AM
I just purchased a 2000 A4 and the key is broken. The blade is broken from the switchblade and the transmitter does not work. I have two questions:
1) Can I put the blade in a new key holder without any problems? I read that there is a transponder somewhere?
2) The dealership says I cannot get a new remote programmed without a second key. Is there any way to get around this? On my old car they just looked up my code in a database a reprogrammed it.
Thanks,
Jason
techbod Jan 29, 2008 11:58 AM
RE: A4 Key Reprogramming
[IMG]local://upfiles/12092/65C7F25D619F447BA56DD19F5269A7DD.jpg[/IMG]
[IMG]local://upfiles/12092/9CC1D75CC31A4AD786B000377DC05DB2.jpg[/IMG]
chaser Jan 29, 2008 12:00 PM
The 2000 doesn't have a transponder. You can buy a new blade on eBay. If the knuckle that the blade attaches to is broken then you need to buy a similar key fob from eBay and use the front half of the fob with your old fob. Did the remote ever work?
jason955 Jan 29, 2008 09:16 PM
I followed the portion of the document that says how to reset the remote if the batteries are changed. The remote still does not work. The reprogramming portion looks like it requires a second key to complete the procedure. I only have one key. Is there any other to reprogram the transmitter??
Thanks for the ebay idea- I bought one just now.
jason955 Jan 30, 2008 06:43 PM
any ideas? Can reprogramming be done with a single key?
chaser Jan 30, 2008 07:07 PM
ORIGINAL: jason955
For my '03 I just started the car with the fob that needed programming and that was it, nothing else to do.
techbod Jan 31, 2008 10:49 AM
fob/key/transponder/immobiliser are all separate systems ( some have them all like in the UK ) but in the states im told they dont have the immobilizer? if not that would simplify things,
the alarm is turned on by the fob as it locks the doors and all you need to do is unlock it with the key to turn it off should the fob become damaged,
in the UK and most other countries the key has a chip in it so only that key can start the car so "no immobilizer means no chip" and chaser is correct;)
