Wheels~~Will they work? Please HELP!
I have a New set of Konig Wheels & Dunlop Tires......I need to know if they will fit on my 2004 A4 Cabriolet. The wheels in question are : 18 x 7.5 5/100/114.45B (offset 45)
Here's the problem.......... Discount Tire doesn't show theses as being a wheel for my car and I also called them and they said they wouldn't work. BUT Today I found the Same wheels on Wheelsnext.com and they are listed as being a wheel to fit my car with the Exception of them being 18 x 8..... Does the 1/2 inch really make that much difference? Man I lovethose wheels and I had just bought them a Month before I totalled my RX8. I Really want to know if there is some way I can use theses wheels. Please Help!! |
RE: Wheels~~Will they work? Please HELP!
check the hole pattern, measure your back spacing. try tirerack.com for that info. it shows up when you select a wheel and tire package.
They are 5 bolt Dual slot.... I was given the impression from Discount tire that they would not be good for the weight distyribution of the car...HUH?
Thanks for the website...I will double check there :) |
FUCZK!!!!!
Looks like the Bolt Patterns specs for my car are 5-112 2Freakin' mm off! Don't suppose they can be Machined?? Or is that a really stupid idea?? |
wouldn't do that.
keep looking. you will find some similar or another pattern you love. sorry to hear regardless. |
Here is what I have...I can re-buy them again to fit the A4, But that SUX!!!!
http://www.discounttire.com/dtcs/fin...&tc=KONFUL |
you can buy an adaptor/spacer that will change your 5x112 on your car to a 5x100, a nice set of 4 would prolly ber about 200-250$
gl! |
Thankies!
I will look into that. I also called a Wheel Repair shop to see if they can change the both pattern 2mm. |
your stuck on those wheels[:'(]
Maybe stuck with them...if I can't sell them :(
I know...I know, I do like the 2 tone wheels...not too flashy and not solid black. |
| All times are GMT -4. The time now is 03:38 AM. |
