-   -   Stock clutch ? (https://www.audiforums.com/forum/b5-models-69/stock-clutch-90906/)
MaXo Feb 8, 2008 04:23 PM
Stock clutch ?
I have only chip on my A4 AEB FWD and my clutch start sliping ... is that normal?What power can hold stock clutch?
viper9821 Feb 8, 2008 05:10 PM
RE: Stock clutch ?
How many miles and do you launch it? Stock clutch can't handle much.
cincyTT Feb 8, 2008 05:12 PM
RE: Stock clutch ?
it can handle stock turbo power fine. Driving style and wear make a clutch go bad.
MaXo Feb 8, 2008 05:13 PM
RE: Stock clutch ?
I have this car from 10 days ...
cincyTT Feb 8, 2008 05:33 PM
RE: Stock clutch ?
either you REALLY cant drive or the previously owner dogged it to death
MaXo Feb 8, 2008 06:21 PM
RE: Stock clutch ?
The problem is not in me ... i can drive. :) Sliping at 3th gear when hit peak of boost ~ 1.4
Bogie Feb 8, 2008 06:29 PM
RE: Stock clutch ?
Either you glazed it up (making it slip till the glaze eventually wears off), oryou need a new clutch.
TDRILL Feb 8, 2008 07:27 PM
RE: Stock clutch ?
ORIGINAL: MaXo
Uh huh. I have heard that from people who go through about a clutch every 18 months too. Its never them and their poor driving, its the car.
You have only had it for 10 days? Couldn't you tell it was slipping during the test drive? Didn't you check?
Whatever, this post is kind of pointless. You need a new clutch. Duh. You can replace with another stocker, or you can upgrade it a bit. You aren't making enough power right now for it to make much of a difference.
MaXo Feb 9, 2008 02:07 AM
RE: Stock clutch ?
I buy stock car without chip ... and then i have no problem with clutch.Thist post is not kind of pointless ... i just want to know what sort of power can hold stock clutch.The problem is not in my drive style...
pyropenguin Feb 9, 2008 02:25 AM
RE: Stock clutch ?
Look into a southbend stg2 TZ or a sb stage 3 if you're going to be doing any launching/driving hard.
stock clutch will be fine if you drive like an old lady.
