-   -   Aftermarket CD-Changers on 2001Symphony? (https://www.audiforums.com/forum/electronics-30/aftermarket-cd-changers-2001symphony-91285/)
Dutch/Allroad2001 Feb 11, 2008 10:50 PM
Does anyone know if there are aftermarket CD-Changers that works with the stock Symphony system??
I've heard of Kenwood with an extra adaptor cable. I currently have a Pioneer, 12 stacker witch the Premier head-unit. Would like to use the Changer in my 2001 Allroad with Nav.So i do not want to change the head-unit.
Thanks.
A4 Effort Feb 28, 2008 10:16 PM
RE: Aftermarket CD-Changers on 2001Symphony?
I believe the Panasonic DP-801 should work with the stock headunit on a '01, but i'm not 100% positive. I know it worked on my stock concert unit in my '99. You would also need to get aBlitzsafe adapter for the HU/CD changer. Check the rear driver's side area in your trunk, underneath the trunkliner and see if you don't have an adapter already.
If you're interested - i have both the CD changer and adapter.
