Headlight alignment???
I did about 6 hours of research on how to raise my headlights in my 07 A4Q. I even have a tech CD. The picture shows two sto turn. I can only find ONE of them and it looks like its the screw that actually REMOVES the headlight. What gives?
Can anyone post a REAL LIFE pic of where to adjust (raise) my headlights. This has been killing me! THanks! |
RE: Headlight alignment???
Take it to the dealer i believe you can do it with a Vag.
There are two adjustments, they can be hard to find. You also need the vag com to tell the control unit that you're adjusting the headlamps, otherwise the adjusting motor will set them back to the original position after you cycle the key.
hmm really, they are not automatic adjusting headlights though.
let me know if thats true for the non-automatic adjusting headlights |
| All times are GMT -4. The time now is 02:39 AM. |
