-   -   Changing H.I.D.S (https://www.audiforums.com/forum/b6-models-70/changing-h-i-d-s-92776/)
Baseballpler Feb 24, 2008 07:54 PM
Changing H.I.D.S
I just got some 6000k bulbs and I was curious how hard it was to replace the factory hidbulbs. I've searched and read that you should remove the whole headlight housing to do so. Is that the only way, or does anyone know of better way to do it? Also If I do remove the headlight housing is it that complicated and will I have to re-aim the headlights manually even though they have the auto-leveling?
x1rider Feb 25, 2008 05:05 PM
RE: Changing H.I.D.S
Here are pics I took when I changed mine about 2 weeks ago.
Remove the headlight housing.
http://i132.photobucket.com/albums/q...ider/bulb3.jpg
Remove the metal clip and open up the back.
http://i132.photobucket.com/albums/q...ider/bulb4.jpg
Slide the metal clip from the rear of the bulb.
http://i132.photobucket.com/albums/q...ider/bulb5.jpg
Unclip the old bulb and pull backward.
http://i132.photobucket.com/albums/q...ider/bulb6.jpg
Remove the connector clip at the bottom.
http://i132.photobucket.com/albums/q...ider/bulb7.jpg
http://i132.photobucket.com/albums/q...ider/bulb8.jpg
Reverse instructions with new bulb.
http://i132.photobucket.com/albums/q...ider/bulb2.jpg
I've removed the headlight housings many times and never had to re-aim them.
Hope this helps.
