headlight problem with my b5
ok so first my headlights dont work, i tried replacing the bulb but no good, for some reason only high beams work and only when i flick them if i try to push out the switch to have them stay on they wont, only when i pull back on the lever they work, any ideas??????
RE: headlight problem with my b5
Sounds like there's something wrong with the switch.
Theres normaly littel plastic clips on the switch it works in esence like a clikc pen maybe the plastic clip that holds it in plce is broken
hopefull that fix will get that done!!!
thanx. |
| All times are GMT -4. The time now is 07:07 PM. |
