Getting a Thud
I have been trying to figure out this thud for a long time now. If I am cruising and let off of the gas and reapply, there is a "thud" sound, driveline slop. There was a previous thread that about it that died. I have replaced the snub mount with the APR. I also replaced the passenger side transmission mount. I have the drivers side but I am going to need a little more time to get that replaced. (Need to heat the bolt, maybe PB blaster or something)I didnt notice any leaking fluid from my motor mounts. Is there a possibility that the driver side tranny mount will make all that difference in the slop? Or is it possible that the motor mounts are just beat?
Thanks for the help |
Alright guys, just figure I'd bump this up to see if anyone found anything.
As of now I have replaced: Motor mounts Snub mount Transmission mounts Apikol rear differential mount Rear differential stabilizer bushings I still get the thud, and Im not sure where else it could be coming from. I think it may be the driveshaft at this point. The center u-joint was solid as a rock when i checked it. The rubber around the center support bearing looked like it has slid and it was fairly soft. I just want the car to drive nicely again. Wheel bearings, control arms, and new suspension are all in order too :/ |
I'm amazed at how many threads there are on this topic lately. Seems a bunch of us are having very similar issues.
Now, if we could just find a cure.... |
a loud thunk when you let off the accelerator is often the rear diff carrier bushings. of none of the other mounts are damaged, i would be looking there.
Originally Posted by ghost6303
(Post 1152110)
my opinion
Why do I think the manual transmission needs a tranny mount near the output shaft?
The only other thing I can think of is one (or some) of the driveshafts. Possibly a CV has some serious play in it? I just replaced the drivers side front because the CV was dry and sloppy.
| All times are GMT -4. The time now is 08:33 PM. |
