-   New Member Welcome Area (https://www.audiforums.com/forum/new-member-welcome-area-4/)
-   -   Audi 80 (https://www.audiforums.com/forum/new-member-welcome-area-4/audi-80-a-1951/)
Smaw Jul 20, 2004 09:45 AM
Audi 80
hi, i have an Audi 80 2.0 inj sport H reg (1990). the car seems to hold back power when i try to accelerate hard, does anyone else have this problem, if so how can it be rectified.
regards
Paul
ImolaS4 Jul 20, 2004 04:10 PM
RE: Audi 80
Hey Smaw, welcome to the forum!
Judging by your H reg comment, I'm going to assume you're in the UK.
Since I'm in the states, I need to clarify a couple of things...
Is it auto or manual?
Does it have any mods?
What's the mileage and what was the most recent maintenance?
Smaw Jul 24, 2004 12:34 PM
RE: Audi 80
Hello imolas4, thanks for replying,
its a manual and the only mod is an ANSA exhaust system from cat back (not really a mod eh) mileage is about 128k
ImolaS4 Jul 24, 2004 09:15 PM
RE: Audi 80
If you bought this used and don't know if the timing belt was replaced, then do so. I'd get the fuel pump and filter done, too. I'd also check the plugs. Are there any oil leaks? Get a vacuum test done for any pressure leaks, too.
As I'm not quite familiar with the 1990 Audi 80, I don't know if it has an MAF. If it does, I'd definitely have it checked and/or replaced.
Smaw Jul 25, 2004 09:43 AM
RE: Audi 80
thanks for the advice, hopefully will sort out the problem. not sure what a MAF is :D
ImolaS4 Jul 25, 2004 04:38 PM
RE: Audi 80
MAF = Mass Air Flow (sensor)
If your car has one, it is located somewhere along the intake between the air filter and the intake manifold.
