How to disable ignition
Greetings!
I am about to do a compression test on my '00 A6 2.8 with about 150K on it; the oil is in the throttle body. I understand that the fuel delivery and ignition must both be disabled for dry and wet compression tests. While I found the fuse for fuel pump, I am not sure how to disable the ignition. Does anybody have a write-up how to do the compression tests on our cars, or how to disable the ignition? My EisaWin softwarewas not much of a help :-( Thanks! |
RE: How to disable ignition
pull out spark plug cables?
| All times are GMT -4. The time now is 01:27 AM. |
