-   -   worn pads light (https://www.audiforums.com/forum/b6-models-70/worn-pads-light-99352/)
CoBra03TerminAtoR Apr 19, 2008 11:09 PM
worn pads light
hey guys i just recently changed my pads and rotors, and from time to time my worn pads light comes on?? what might cause this do you know?
JayEffy22 Apr 20, 2008 01:01 AM
RE: worn pads light
The light that comes on is a sensor that hooks in to your pad.
when you changed it, you should have swapped it out with a new one.. (it comes with the new pad)
if this isn't 'connected' all the way, it could cause it to short out when wet...
or
have you checked/drained out brake fluid?
hope this helped,
i ended up chaning my brakes because that light wouldn't go off.
i put in Drilled/slotted rotors
with EBC "red stuff" pads...
and when i was changing my front passenger brake, i realized that my sensor had just melted on me
and thats why my light was on..
but
those new brakes, literally saved my life!!!
Jay
CoBra03TerminAtoR Apr 20, 2008 01:07 PM
RE: worn pads light
thanks for the input!! the sensors are nice to have i just wish they would have made a little beter design to them its so tight in there and the connectors are a pain in the a$$ but oh well lol if it keeps it up over the next few weeks i will try having it erased if i can?
david9999 Apr 23, 2008 11:50 AM
RE: worn pads light
The light will stay on as long as the sensor is malfunctioning. It is a straight electrical connection, not a "Code" that can be erased.
