-   -   Coolant leaks ---- My first post (https://www.audiforums.com/forum/b6-models-70/coolant-leaks-my-first-post-100004/)
A4gulu Apr 25, 2008 06:04 AM
This is my first post on this forum, hope I can find the answer.
Found leaks as per attached photo, anyone ever encounter this, and how do you fix it? With picture will be highly appreciated.
[IMG]local://upfiles/52417/81FB4FBB387E41BFAAD409AA618ACBD5.jpg[/IMG]
dahonam Apr 25, 2008 01:37 PM
RE: Coolant leaks ---- My first post
Looks like a seal is probably corroded... try to take off that "cap" and see if there was a seal/gasket there, if so replace it... the leak doesn't look that serious anyways
A4gulu Apr 25, 2008 07:57 PM
How to take the cap off the pipe or any tricks included.
I tried to unscrew it off but it seems the cap didn't even move andtends to break.
AudiTech616 Apr 26, 2008 12:51 PM
Just twist it and break off wat you can. Then drill out the center of the screw with a smaller size bite not the damage the threads on the pipe. then pick out the remaining pieces and put and new coolant bleeder screw.
A4gulu Apr 26, 2008 10:43 PM
Thanks AudiTech616.
by the way do you know the part number of the Coolant bleeder screw, so I can prepare one before breaking it.
AudiTech616 Apr 28, 2008 11:10 PM
Sorry don't know the part #. But the dealer should know what your talking about when you ask for it. It's common for those screws to leaks.
