-   -   98 a4 2.8 vs. '06 mazda rx8 (https://www.audiforums.com/forum/b5-models-69/98-a4-2-8-vs-06-mazda-rx8-100564/)
kmoney Apr 29, 2008 08:37 PM
hey im just looking for some other opinions, i own a 1998 audi a4 2.8Q with a K&N intake and a Speedtuning chip and i was asked to race a stock 2006 mazda rx8...i could either pick a 1/4 mile race or 3/4 mile do you think i would have a chance of winning, and which distance doyou think the car would perform better in vs. the rx8
CIA Apr 29, 2008 08:48 PM
RE: 98 a4 2.8 vs. '06 mazda rx8
RX8[/align][/align]
[/align][/align]
•[/align]2,616 cc 2.6 liters rotary 2 front engine with 0 mm bore, 0 mm stroke, 10 compression ratio, none and zero valves per cylinder RENESIS[/align][/align][/align][/align]
•[/align]Power: 158 kW , 212 HP SAE @ 7,500 rpm; 159 ft lb , 216 Nm @ 5,500 rpm[/align]
[/align]
[/align][/align]
Audi:[/align][/align]
[/align][/align]
2,771 cc 2.8 liters 6 V front longitudinal engine with 82.5 mm bore, 86.4 mm stroke, 10.3 compression ratio, cast iron block, light alloy head, double overhead cam, variable valve timing/camshaft and five valves per cylinder
[/align]
-[/align]Power: 142 kW , 190 HP @ 6,000 rpm; 207 ft lb , 281 Nm @ 3,200 rpm[/align]
[/align][/align]
[/align][/align]
sineo Apr 29, 2008 08:52 PM
I think you don't have a chance in either distance, assuming the RX8 driver is at least semi-capable.
01afour Apr 29, 2008 09:11 PM
im not even gunna read this one and i say good luck.
mr.cAp Apr 29, 2008 09:36 PM
walk you hard either way,
chaos92287 Apr 29, 2008 09:57 PM
your both running a ~15 sec quarter mile. its gona come down to the driver. but keep it at a quarter mile, he should walk away from you after that
FACT Apr 29, 2008 11:00 PM
lol throw a supercharger on there and try again
feerocknok Apr 29, 2008 11:09 PM
Those RX-8s aren't fast, they just look it. But he'd take you.
mhellman Apr 29, 2008 11:23 PM
I was under the impression that the A4 with the 2.8 would run closer to a 16 second 1/4 mile? (i.e. it's about as fast as my Odyssey minivan):D
sineo Apr 29, 2008 11:25 PM
ORIGINAL: mhellman
Either way, it's not going to beat an RX8.
