-   -   driver window problem (https://www.audiforums.com/forum/b6-models-70/driver-window-problem-100667/)
awreadie Apr 30, 2008 06:56 PM
I drove to the bank and my windows were working fine. I came back out and rolled down the driver window and it made a weird, nasty sound. it was struggling to go down. Now its getting stuck when it's down. And it'll come up sometimes. It makes a nasty sound and struggles. I don't know what happened. I just bought the car about two months ago. Any suggestion would be helpful.
auditurbo381 Apr 30, 2008 06:57 PM
RE: driver window problem
possibly pull the door panel and see if everything lining up?!
thats odd.
awreadie Apr 30, 2008 06:58 PM
the thing is..im new to audi. so im not familiar with taking things apart haha. it is weird. it was working just fine. then i came out and it goes crazy.
awreadie Apr 30, 2008 07:45 PM
i searched around on the forum, and it sounds like the window guide. I couldn't find it on ECS. It only has it for A6. Does anyone know where i can find one for a '04 A4?
pmkcolorado May 1, 2008 09:03 AM
Had the same problem...go to the DYI on how to remove door panel...very easy, just remember that the upper trip piece slides toward the inside to release, find and remove all fasteners in order to lift up the top molding @ glass (some are difficult to see); don't tear the liner;or break the electric connecters- the front door has a "flip" release so look carefully - don't try pulling apart.
The window works by a drive cable connected to a plastic guide attached to the window rail. The cable rarely breaks, however, the plastic guide pins do which allow the cable to jump out of its track. I did not replace the inside plastic, instead, I used epoxy to glue back the broken plastic and also used a piece of wire as a "clamp" where the plastic had broken. I did this by drilling two small holes, and creating a "ring" at the weak point. Sounds like alot of work, however, took me less than one hour. I know that my repair is far stronger than the original piece...probably will fail again in another areain the future as the plastic may be fatigued.
good luck
ControlFreak May 1, 2008 02:27 PM
ORIGINAL: pmkcolorado
good luck
can you put a link to the section on removing the door panels? My window switches are crapping out on my A4 and I need to change them. I tried to remove the panel but got scared that I would start breaking parts.
surfntomm May 2, 2008 12:26 AM
my passenger side window was doing the same, i took my door apart multiple times and its quite easy and straightforware. my problem turned out to be that the cable popped off its track and ruined the white spindle where it spools onto and kinked itself. i replace the cables with some that i made myself but the spindle is quite damaged so the cables dont like to spool nicely now. its a 100$ part to fix to get the entire window regulator.
awreadie May 5, 2008 09:04 PM
ok so i decided to replace the whole front left window regulator. Does anyone know how to replace it? If its hard, i will probably take it to a shop.
