-   -   valve cover gasket??????? (https://www.audiforums.com/forum/b5-models-69/valve-cover-gasket-100795/)
vlado182000 May 1, 2008 08:40 PM
hey guys do you need to put gasket sealant all the way around valve cover or just on the corners? some people told me not to put any because the gasket may not sit properly.
help guys
sineo May 1, 2008 08:42 PM
RE: valve cover gasket???????
You shouldn't have to use any at all, but if you do, just put it at the corners.
chaos92287 May 2, 2008 03:20 AM
ORIGINAL: TomRitt
After that clean off the mating surfaces on the head and the valve cover with a clean rag. Don't forget the center 4 holes for the spark plugs as well. After this apply a very light layer of gasket sealer/rtv along both the front and back of the motor especially in the corners and the "v" part of the head. Also apply to the matching side of the valve cover. (In the pic I only have the corners done but do all the way across the front and back of the motor.)
https://www.audiforums.com/m_61552/tm.htm
fred2ka4 May 2, 2008 01:50 PM
I recently did my valve cover and I pretty much only added sealant (lightly) only on the corners and around the holes fo rthe spark plugs. Just remember to start from the center and work your way out when re-tightening. I have not had any problems with leaking at all.
vlado182000 May 3, 2008 09:45 AM
thanks for help guys
cincyTT May 3, 2008 04:10 PM
I did it twice and never used sealent. There is no need to and you are just adding in more crap between the head and cover.
