-   -   Airbag Fault after running Vag-Com (https://www.audiforums.com/forum/general-tech-50/airbag-fault-after-running-vag-com-101145/)
djlouieboom May 5, 2008 01:06 PM
I have a 2001 Audi A4 1.8T , i ran the Vag-Com and got these faults for the airbag system.
65535 Internal Control Module Error 00-00
00588 Airbag Ingniter (N95) driver's sdie can't Unlock intermittent 59-10
The Airbag annunciator on the instrument cluster is not on and goes ouut after it does its self test after i strart the car.
Anyone have any sugestions ??
CRAZYHAWK May 5, 2008 01:50 PM
RE: Airbag Fault after running Vag-Com
Reset the code, and see if it returns.
djlouieboom May 5, 2008 03:29 PM
Sorry yes i have cleared the code's and they come back. is there any may to reconfigure the airbag contorl module with the vag-com ?
tHe kNiGHt FaLL May 5, 2008 06:49 PM
i'd consult your dealer... cause there is a airbag fault out there w/ a malfunctioning control module that can randomly deploy all airbags at any moments notice.
its a pretty serious concern. i'm not too familar w/ years and models affected. but i know it to be a fact.
djlouieboom May 6, 2008 09:29 AM
to be honest i dont want to consult my audi dealer, because i hate dealing with "the dealer", what would cause the airbag control module to have an internal memory error ? and why all of the suddden is the steering wheel airbag igniter intermittent ? i have not had any accident historyserious enough to even trigger the airbags. I really dont wanna go and buy a new control module, and steering wheel airbag thats a lot of money,....
Tgood May 6, 2008 02:59 PM
65535 error on your controller is a badcontroller. You can't clear the error with vag-com due to liability issues. You have three basic choices.
1) New controller from the dealer. 700 bucks, I think.
2) Used controller. 100-400 bucks, depending on who you buy it from.
3) Send thecontroller to one of the ebay controller repair persons. Never done it, so who knows what the results are.
The question is, what is your safety and the safety of your passengers worth to you.
Dallas09 May 7, 2008 09:37 PM
Its probably likely the airbag iginiter warning and anything else is probably false since the module seems bad. It would be pretty coincidental for them both to be there at the same time, step 1 is probably the control module.
djlouieboom May 7, 2008 10:04 PM
waht i dont understand is the system paases its self test everytime and the airbag light is not on, wouldnt the airbag light be on since the module is bad ?
manin59 May 10, 2008 04:02 PM
Either one of thefaults has to cause the airbag light to go on. Have you ever checked the codes since you got the car?
djlouieboom May 10, 2008 04:55 PM
Niehter fault is putting the airbag light on, i have checked codes since i have had the car and these showed up recently
