headlight
Both of my headlamps have built a yellow kind of crust looking film over them, it makes the car look old and dirty, does anyone know any products that can remove this, i think its on the outside. Also the bottom right grill piece that surrounds my bottom right fog light is missing, i located some on ebay and you could only buy 2 and shipping was 50 bucks!
RE: headlight
Hey turbo,
Try out: http://www.crystalviewchemicals.com/ Please post before and after images if possible, I've been thinking about it, just haven't had the time to do it! |
RE: headlight
This is pretty close to how I polished mine. |
RE: headlight
wet sand them and then clear coat them, finally polish them with plasticx and you should be good
takes about an hour per headlight if you want it done right. also if you take the headlights out of the car its easier and you can do a better job. |
RE: headlight
ORIGINAL: gottwinns wet sand them and then clear coat them, finally polish them with plasticx and you should be good takes about an hour per headlight if you want it done right. also if you take the headlights out of the car its easier and you can do a better job. http://www.popularmechanics.com/auto...o/4252611.html |
| All times are GMT -4. The time now is 05:30 PM. |
