Repairs
I know i should get the bentley, but i just got quoted and wasnt happy with the price for these repairs:
Coolant Tank Replace Replace valve cover gaskets Control Arm Bushings Aux Water pump replace. How difficult are these to do? i kno the coolant tank is pretty easy. Im only a moderately experienced wrencher. |
RE: Repairs
not to hard as long as you take your time, and have a weekend free.
RE: Repairs
the control arm bushings i wouldnt advise u to do or the valve cover gaskets... if u were more experienced id say go for it. but better safe than sorry
RE: Repairs
a monkey can change the coolant tank
RE: Repairs
Im 17 and just did my valve cover and replaced my control arms not too hard. Like stated above, if you take your time its a walk in the park.
RE: Repairs
ORIGINAL: Blue_S4 a monkey can change the coolant tank I dont know how anyone can let the car slip this badly, i just got the recommended repairs and it goes to the tune of: Done: COMPLETE rebuild drivers rear brake replace pad and rotor on passenger side rear brake new pads both front brakes change oil Change brake fluid Need: MAYBE replace caliper on pass. rear brake replace coolant tank (part already ordered) replace aux water pump valve cover gasket replace control arm bushing replace slightly torn TBB Shocks need replacing and my personal fav. The shifter is bent so you have to really hard jam it into 2nd or it will just go into 4th. not really sure how you would bend a shifter, but this dude managed. but the good news is he replaced the diverter valves and the turbos are in amazing shape. oh, the humanity.... |
| All times are GMT -4. The time now is 03:20 AM. |
