-   -   Swapping Tiptronic Trannys in 99 A4 1.8TQ (https://www.audiforums.com/forum/b5-models-69/swapping-tiptronic-trannys-99-a4-1-8tq-104924/)
Jeepersinco Jun 12, 2008 07:01 PM
My tranny bit the dust and I'm trying to find a replacement. I need to know for certain if I need a tranny with the same code? For example I see tranny's from other 99's with a different code and some have said that they can be used. My local shop says even though
it will work, the ECU never recognizes it correctly flags the CEL and puts it into limp mode.
Even if you replace the TCU they have the same results. Does anyone have first hand experience with this????
I've only had it for two weeks so I don't have a clue.
Thanks in advance.
Jim I
Colorado
jeepersinco@aol.com
scotty@advauto Jun 12, 2008 09:23 PM
RE: Swapping Tiptronic Trannys in 99 A4 1.8TQ
You need to stick with the same trans code.
