-   S Car Model Line (https://www.audiforums.com/forum/s-car-model-line-13/)
-   -   SS Autochrome (https://www.audiforums.com/forum/s-car-model-line-13/ss-autochrome-106768/)
tpc303 Jul 2, 2008 08:16 PM
SS Autochrome
How good is the SS Autochrome exhuast?
readimag Jul 2, 2008 08:26 PM
RE: SS Autochrome
for the price it is good, not the cleanest welds but they are ok. I am running it on my car right now and I am a stage 3 to do a test on how it works with k04s. so far i have not had any problems other then the lower dps dont fit to the spring bolt for support. i also have have pops then i am done with WOT runs on cool downs. I looked under my car later and jsut made the clamps even tighter and have not had the problem sence. I still get my the same whine as with piggies jsut more noise at WOT , lol or so my friends tell me when I go by. If you guys want I can get some more sound clips up and video, also I will try under WOT but the wind takes away alot of what the mic can do. Hope this helps at all just keep asking questions and remember to search, cause I know this has been talked about SOME what.
cheers,
Paul
tpc303 Jul 2, 2008 08:37 PM
RE: SS Autochrome
Yeah the sound clips would be great!
meatbiscuit Jul 3, 2008 12:44 AM
RE: SS Autochrome
It would be great if you can post some sound clips, I'm trying to compare it to borla/awe twin 2, and most of the recordings out there aren't that great. We could use a higher quality sound clip
tpc303 Jul 3, 2008 01:09 AM
RE: SS Autochrome
I'm trying to compare it to the AWE Twin 1, hopefully it compares well cause it's a hell of a lot cheaper
meatbiscuit Jul 3, 2008 10:36 AM
RE: SS Autochrome
Are you planning on cutting out the second muffler? The twin 1 will most likely be louder and more aggressive, it only uses 1 muffler. The SSA and the Twin 2 use two mufflers.
readimag Jul 3, 2008 11:41 AM
RE: SS Autochrome
I was planning on take out the second muffler but got lazy and just put it on, I will have the vids up this weedend, just post what clips you want and I will try to do those for everyone.
cheers,
paul
oshburg Jul 3, 2008 12:22 PM
RE: SS Autochrome
Will the SS Autochrome Catback bolt right up to the stock downpipes? I really only want to add a catback.
readimag Jul 3, 2008 12:31 PM
RE: SS Autochrome
Yes it will
eliTTe Jul 3, 2008 10:52 PM
RE: SS Autochrome
so how well did the DP bolt up? as long as they bolt to the turbo fine and fit, I might get them before too long. and I can split with someone if they only want the catback!
