APR ECU Upgrade - to buy or not to buy
So I am currently torn between getting the APR ECU upgrade or not. Here are the pros and cons that I have thought of:
Pros ==== -extra horsepower and torque -faster -better -retains factory like smoothness -uses encryption -lifetime free updates -30 day money back guarantee -FlipSwitch - 2 programsis free the month of July (savings of $149) Cons ==== -Expensive (~$720 that includes tax and labor) -Could potentially break something which may or may not be covered under warranty -Your dealer finding out that you chipped your car, then voidmy warranty -Not being told any secrets that the chip upgrade could cause damage wise down the road I realize that $720 is pretty cheap to get ~41 extra horsepower, but do the pros outweigh the cons? I think my wife would kill me if something would happen to the car, and it potentially voids the warranty and/or requires $$$$ to repair something that may break. Help me make up my mind!! -Blake |
RE: APR ECU Upgrade - to buy or not to buy
your dv valve will fail.....i chipped my car and withen the week it failed..... due to the magnus moss act the dealership can't entirely void your warranty, if there is a problem directly related to you chipping the car then yeah they won't cover you, you should look into other manufacturers of chips because i used unitronics and it ran me 670 for everything, i ended up with 55hp and 65lbs of additional torque
the weird thing is that i actually get better mileage with the chip then i previously did....i say go for it....as long as you perform regualr matinence and care (and a forge dv) for your car you'll be fine, it really makes the car alot more fun to drive |
dmfan016,
What year is your Audi? I was told by the APR Rep that the 08's have a higher revision of the DV, and they have not seen many issues with it. I plan on calling APR back to confirm this. Thanks for your response. -Blake |
i went with GIAC and am very happy. it definately puts me back in my seat when i stepped on it. Luckily I have only gone through one DV valve. Ive had the chip for almost a good year. I paid $220 to get the DV valve replaced.
i would honestly go with the chip... if you are considering it enough, and think that eventually down the road you are gonna get it, you might as well get it now while the deal is going on so you can get the free programs and save $150... but thats just my $.02
i have an 08 quattro and i blew my dv in less then a week its still a plastic DV no matter what revisions they did....plastic is weak
dmfan016, what did you replace it with? Another factory branded or aftermarket?
Per APR, the G Revision DV has been up to par, and they have not had any issues in their testing. Thoughts? -Blake |
if your looking for an aftermarket dv, forge has a lot that ppl like to put on their audi's, one of the most popular is the 007 forge dv
ORIGINAL: bem1 dmfan016, What year is your Audi? I was told by the APR Rep that the 08's have a higher revision of the DV, and they have not seen many issues with it. I plan on calling APR back to confirm this. Thanks for your response. -Blake |
Get the chip, no question... it really does make a difference. also there are numerous others who have driven many miles on chipped car with same DV and had no problems and I've heard the failure rate is not all that much higher on a chipped a4 than it is stock...
| All times are GMT -4. The time now is 11:20 PM. |
