Is there a difference in these carbonios?
hey guys. just wondering if someone could tell me the difference in these two carbonio intakes:
http://www.bursethracing.com/product.../productID/587 http://www.goapr.com/Audi/products/i...onio_b5a4.html the pictures are different but im not sure if there is a performance diference...? thanks. |
RE: Is there a difference in these carbonios?
I believe the first one is an early model, and the second is a remodel.
Supposedly the first generation was to expensive to continue making as the entire housing was constructed out of molded carbon fiber, (I used to have one) with a reversed K&N style filter on the inside.
The revised model only has a carbon fiber cover and uses a foam style filter. Are there any differences? Carbonio says the revision was for better flow, but I think it was just to expensive to make. The only reason I sold mine was because I designed my own and it works and looks great. I also incorporated a velocity stack in order to smooth the airflow prior to the MAF. |
| All times are GMT -4. The time now is 08:39 PM. |
