Just got my claybar!
Wow.. So I got my clay bar and went to town on my trunk... holy crap I want more!! this stuff seriously kicks arse!
RE: Just got my claybar!
Yeah, clay bars are amazing, especially if you had never used one before.
I have a white car.. and it really helped.. couldnt believe it
Yeppers. They are amazing on all colors.
You may be able to 'improve' the look of white paint by also chemically cleaning the paint
- To prepare paint surface to accept a wax /polymer sealant and not adversely effect there durability or optical properties will take a combination of products. Detailer’s clay will remove the surface contaminants, used in conjunction with a mildly abrasive chemical cleaner (Klasse All-In-One) to clean the micro fissures left in the surface and restore the paints gloss. JonM |
how do you know when you should retire your clay bar, and start using a fresh one?
When you can’t find a ‘clean’ (obviously a relative term) surface by kneading the clay its time to relegate it to glass surfaces, once it gets soiled from this use relegate it to wheel surfaces
JonM |
i just got a mothers clay bar and it says that it can be used 3 times (3 full cars)
They are in the business to sell clay. . .
Divide the Detailer's Clay into equal pieces and knead into a ball to ensure pliability (usually each ¼ piece will ‘clean’ two vehicles, it can then be relegated to wheel surfaces and then glass) Take one of the pieces and flatten it out into a circle, approximately enough that it will fit into two or three fingers Spray a 2-foot by 2-foot surface with a lubricating solution (WooliteTM or Dreft™ / Water 5:1), ensure that the surface being clayed is always wet (important enough to restate- ensure that the surface being clayed is always wet) JonM |
OMGFG, i just got one, it is a godsend mmmmmmmmmmmm sexy:D
| All times are GMT -4. The time now is 06:29 PM. |
