+ ABS & ESP LIGHTS ON DASH
I had the car vaged and have the following
DTC 18265 P1857-35-0 LOAD SIGNAL - ERROR MESSAGE FROM ECU What does this mean? |
Sensor
Sounds like one of the ABS senors has broken down if you have access to VAG this can be tested. Go into
brakes 03 Read measured value blocks 08 001 this will display the readouts of the ABS sensors for all four wheels, then just drive the car while monitoring the read outs and see if any are diffrent to the rest. If so the ABS sensor requires replacment. |
RE: Sensor
Thanks, I'll let the guy who Vaged my car know.
RE: Sensor
Last weekend, I removed each wheel and hit each brake caliper lightly with a one pound hammer. I freed the dust on the wheel sensors and now the ESP and ABS work. The dash indicators went out after being reset with a computer.
RE: Sensor
This is for nirvana.
| All times are GMT -4. The time now is 12:47 PM. |
