1985 Audi Coupe GT help.
Old Mar 9, 2005 | 02:34 AM
Ignition's Avatar
Default RE: 1985 Audi Coupe GT help.
sorry, i am kinda lost when it comes to my car.. i have no idea whats wring with it and what kind of information you guys need.
Old Mar 9, 2005 | 04:02 AM
gmatov's Avatar
There's not a heck of a lot more we need, unless you are going to try a few things, and I don't know your mechanical skills.
If you can introduce 100 lbs or so of compressed air into each cylinder to try to see if you have a leak into the coolant passages, and you will know by the bubbles in the expansion tank, if not by the tank blowing water out the cap, anyhow, if you don't, with a warm engine, one point passed.
The other is the possibly blocked, at least partially, radiator, again, which may have had Stop Leak used in the past, maybe for a heater leak.
Generally, the fan runs at low speed to keep the engine coolant within range, high speed in prolonged traffic in hot weather, high speed when the AC is running in hot weather, no low speed in AC mode, as you are cooling not only the radiator, but the condensor, also, double the thickness of tubes and fins. And at least double the heat to be dissipated.
Well, maybe not double, but you are drawing hot air from the condensor past the radiator to try to cool the radiator, and cooling is by the delta T of the air, and if you are trying to cool a radiator with already hot air, it will not be very efficient.
Come back after you have tried a few things, maybe more help will be available.
Cheers,
George
stowaway322
Jan 1, 2014 07:49 PM
laydback
Sep 1, 2009 10:32 AM
Flat Black MK3
May 7, 2007 10:01 PM
DJ Duffy
Apr 18, 2007 04:48 AM
joshj
Dec 10, 2006 08:09 PM
