Go Back  AudiForums.com > Audi Models > All Other Audi Models
'91 Audi 100...eating alternator belts..HELP! >
Old 12-13-2009, 08:38 PM
Location: I live just outside the Boston area in the MetroWest region
Exclamation '91 Audi 100...eating alternator belts..HELP!
Greetings from Boston!
I just bought a 1991 Audi 100 in good condition with just 94K on it. It's not perfect, but runs pretty well. The only real problem I have is that this thing keeps eating alternator belts. I've put two on in the last 72 hours and the last one has turned itself inside out (teeth showing). WTF?
The pullies seem to be correctly aligned.
The cam seems to be OK (hard to tell).
Has anyone had this experience and can give me a solution? Is is possible to eliminate the cam mechanism and use some type of standard bolt/bracket mounting set up?
Thanks for the help!
Kurt...a/k/a the LeLimoMan
Old 12-13-2009, 09:18 PM
b4thea4's Avatar
Member
The only thing I can think of is that things either aren't aligned or something is getting loose and allowing some slop. When you put the new belt on how much slack do you have?
Old 12-14-2009, 09:15 PM
Thanks for the reply b4thea4.
I have the belt pretty tight with less than a 1/2" deflection.
I spoke with the people from Shokan in NY and they think it might be the rubber harmonic balancer is going bad and causing things to shake and the belt to jump. Doesn't sound like the easiest job to replace it.
Any more thoughts out there in Audi Land?
Thanks!
Old 12-20-2009, 06:48 PM
b4thea4's Avatar
Member
Does it eat the belt right away?
If not, can you start the car, run up front and watch what happens? It may give some clues.
For me, I didn't have the belt tensioned correctly and ate a belt or two.
Hopefully you'll figure it out with out having to mess with the crank pulley.
newbaudi
09-25-2014 02:50 PM
LeLimoMan
12-13-2009 06:47 PM
xqwizit
11-02-2008 04:55 AM
PhatPipe
01-03-2008 11:43 PM
Quick Reply: '91 Audi 100...eating alternator belts..HELP!
Advertising
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
