audi 100 airflow meter
I have an audi 100 2ltr avant estate k reg (1993),i have had problems starting the car when cold,i have replaced the battery,plugs,airfilter,rotor arm and distibuter cap to no avail,I have been told it may be an airflow meter fault or could it be something else, help....any info would be great!! Thanks Ray
RE: audi 100 airflow meter
Does your "Cold Start Enrichment Valve" and "Thermo-time switch" work? Injector is on the rear end of the intake manifold, held in with 2 bolts, switch is in the radiator.
There is a time graph in the manual that tells you how long the enrichment valve should be open at any given temperature. This is the equivalent of a choke on a carbureted engine. Cheers, George |
Your car is probably equipped with the Bosch LH-Jetronic system. If the Mass airflow sensor (MAS) is at fault you should be able to read some fault codes stored in the CPU. However I don't know the procedure for the Euro models.
I gotta give a correction on the "cold start valve". On my old car it was at the rear of the manifold, on my '90 100, it is about at the middle of the manifold on the left side, passenger side US autos.
Hell, the whole manifold is different from the older cars. Uh-huh, my car is 15 years old, and I love it, and talk about the "older cars". Go figure. Who can brag about their 15 year old Ford or Chevy? Cheers, George I really would like to get closer to 2000 model, though, price permitting.:):) |
