AudiForums.com
-   All Other Audi Models (https://www.audiforums.com/forum/all-other-audi-models-11/)
-   -   AUDI 4000 4 CYL MISSING/ NO IDLE (https://www.audiforums.com/forum/all-other-audi-models-11/audi-4000-4-cyl-missing-no-idle-32354/)
darrin 05-22-2006 03:57 PM
My 84 4000 misses bad and will not idlle at all most of the time. This is a bad miss not a slight spit. It is not just one cylinder not hitting it is a serious miss. It makes no difference at what rpm it is run at. It has no power and is unusable. Electrical or fuel?? thanks
techbod 05-22-2006 04:03 PM
RE: AUDI 4000 4 CYL MISSING/ NO IDLE
check all vacuum pipes/clean the idle control/bypass valve and pipe work check the main vacuum pipe under the inlet manifold ( the pipe comes of the top of the rocker cover and goes under the inlet manifold and is a common cause for breaking down and rubber rotting
0fframp 05-22-2006 09:19 PM
Had a 4000S with similar problem, tensioner pulley froze and belt skipped two teeth.
