AUDI 90, 1991
Hi:
Does any one know if AUDI 90, 1991 needs to change timing belt? I am interested in on very cheap AUDI 90, 1991. The owner told me that this car use another method and has no timing belt. it is ture? Thanks, |
RE: AUDI 90, 1991
unless someone swapped in a Wankel or turbine or something, the car has a timing belt.
RE: AUDI 90, 1991
I believe you can drive it untill the belt goes, then just replace it and drive some more.
correct me if I'm wrong, thoughs engines are non intefiring 4 cyl >1.8L and 5 cyl |
RE: AUDI 90, 1991
Hi:
Thanks for the answers. but does it need to be changed?? Please see the link: http://yarchive.net/car/timing_belt.html Also, in the 1991 models (Audi maintenance), it indicated: Additional Vechicle Maintenance every 90,000 miles -- Toothed belt: Replace (Audi V8 only) So 1. is the toothed belt = timing belt? 2. does it mean that other models in 1991 (except V8) donot need to change timing belt?? thanks, |
RE: AUDI 90, 1991
1. YES
2. No, it means if on V8 or V6 belt goes valves are beaned and would need a lot of repairs. for 4 and 5 cyl if belts goes you will be straineded some where |
