audi cabriolet brakes
RE: audi cabriolet brakes
you'll need a rather large hex key ... do to the fact that the e brake works off the rear calipers .. the pistons actually scruew back in ... look carefully on top of the piston there might be a heat shield of sots there or lots of dirt thats preventing you from seeing the hex slot on top of the piston
I use regular clamp. I think I used 2" clamp but bigger be better. also you can put the old pads back in, and use a crow bar or large screw driver to pull pads apart. Also the E brake might give you problems, so just unplug it as well. I think lust pull the leaver with a screw driver and pull the cable out. it just has to be not in contact.
hpelyno
02-02-2015 06:33 AM
