cam/crank sensor Q
hello everyone. i bought a 93 cs quattro for a song and dance w/ blown head gaskets(suprise). rebuilt whole motor and replaced all gaskets etc and a few sensors- now i see the cam sensor has age/heat cracks. i just bought a crank sensor 4 $130 due to oil pressure blowing oil into the harness(suprise). will this DME let the motor start of the crank sensor alone? it wont start and im tapped out. thanks
RE: cam/crank sensor Q
how is the timming
the timing is set to cyl 1 TDC with the cam bar and crank marks (cover and pulley) lined up
(basically i have compression and its interference so the timing must be right...right?)
it still could bee of enough not to start .. or 180deg off
timing set up ( engine size is always good to know ) but 1 cylinder head ? I guess its a 2.2 or 2.3
# [IMG]local://upfiles/12092/73DBFFBE7C464EFFBC2BD464248ABCA3.jpg[/IMG] |
its a 2.8 (6) cylinder
