fuel pump
fuel pump runs with jumper, relay energizes with jumper , 12v power at ter 46 with ignition on under relay. terminal 47 to ignition control [ right kick panel ] connector showes nothing on any contact. the only manual i have is for a 5000, the ignition control connector is different, fewer contacts. any thoughts anyone?
RE: fuel pump
are you saying there is no fuel to motor ... in that case the fuel pump can still "make noise" but not deliver fuel -> impeler in side the fuel pump is broken off
RE: fuel pump
try another fuel pump relay this sounds like your problem
