Fuel pump
Looks like my fuel pump sized.
I checked the voltage to the pump when you turn the igniotion, and it looks like it sends 12.6V to it then turns off. Then I cheked the resitence of the fuel pump, it gave me 0.6ohms, I thinks thats bad. Then I cheked the fuel sender resistence and it was 75.5 Ohms. so I guess I will need a fuel pump, Any good cheap place I can get it at? |
RE: Fuel pump
breakers yard ? I assume its Bosch and external ( same as the Mercedes )
RE: Fuel pump
I think its internal in the tank, couse there are 4 wires going in, 2 thin, 2 thick.
Should I gamble on an used pump? I dont know, its my first fuel pump failure. |
RE: Fuel pump
my pump meraculasly started to run, so now car still wont start, I checked the CEL, and it gave me 2113.
I actually rember people with that problem. Camshaft potiion sensor. Car actually managed to start ones, which is wierd. So I have ether bad sensor or bad wiring. Or bad timing. |
RE: Fuel pump
2113 is insecure cam shaft sensor/rotor, wiring, poor connection, fuse, distributor/cam shaft alignment, cam sensor
RE: Fuel pump
it could easily be timing is out so adjust the distributor to correct it ( if you can that is)?
RE: Fuel pump
I dont think I can adjust the timing on mine, it just has to be perfectly alighned. I will go out soon and check the sensor, ground, power for it.
RE: Fuel pump
used fuel pump is bad .... i think there is abetter version made by pieburg or someting like that ... you can advance or delay the timing with hte help of a distributor
