HELP!!!! 1995 Audi Cabriolet
Ok so i just bought my first car and it was an AUDI :cool: So its not in the best shape but it moves.............with minor problems :confused: ,
first off i cant get the top to go down. When I unlatch the top the windows go down about 6" like their supposed to, and the light in the dash is on. when i pull the roof switch up it does nothing, then i relatch the top and press the same switch and the windows go back up:( So I've been reading around and i heard about the wires in the trunk, so i looked at them and the driver side had been repaired, and the other was still in the sheath...... So i cut all the visible sheathing off of both sides and re-repaired the one side and taped some nicks up on the other side. Tried again no luck :mad: ok now the hunt for the motor began. tore the lining out of the trunk and found it and saw it was low on fluid.... would this cause the motor not to run??????? Any help would be GREATLY appreciated. :D Thanks, Tin |
