HELP Audi 90 window problems
i have same car and on occassion the driver side door controls do something and i hit the window lock and they work again. also, i have ignition switch problem that affects windows. so you can try jiggling the key and maybe it work. good luck.
If none of your windows work it's your Window Control Unit/Relay. It's a weird double sided relay, should be part # 443 959 257A or 257B. These are expensive from the dealer but cheap from a junkyard. Now like the problem i've had with mine is that none of the DRIVER's door switches work, in that cause it is actually all of the switches. The drivers door is more seceptible to weathering and coffee spillage and the sort. if you want a quick fix in this case just switch out the back two with the front two on the driver's door and you can operate both front windows until you can get new switches. Any questions feel free to ask. Good Luck
-Shaun
-Shaun
